KB57617
Published: July 6, 2007
'Set Analog Filter Weight' command may disable I/O unit
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was discovered in version: R8.0b, B7.2a Ultimate I/O firmware
Problem is fixed in version: R8.0d SNAP PAC firmware, R7.2d Ultimate I/O firmware
The Set Analog Filter Weight command in PAC Control/ioControl disables the analog point's I/O unit. Errors ‑29 and ‑534 are placed in the controller error queue.
