KB57625
Published: July 16, 2007
PAC Display historic logging may fail the first time the log file is written to
Problem was discovered in version: R8.0g
Problem is fixed in version: R8.0h
When you set up PAC Display to use a controller string variable for a historic log file name, an error may be posted to the event log the first time the log file is written to. The message "Bad string from control engine (zero-length). Using default file name." appears in the event log the first time the historic log is triggered. Subsequent logging to the default file name works correctly.
