KB57630
Published: November 7, 2007
Analog input averaging on a B2 stops if input readings go out of range
B2
Problem was discovered in version: 9183a, 20303.00
Problem is fixed in version: B20303A label on EPROM
If analog input averaging is configured by a B2 on an analog input module, and the readings go out of range, input averaging stops. Once analog readings are within range again, analog averaging does not restart. It must be restarted by sending the Optomux command "T", "Start Averaging Inputs" to the B2 brain board.
