KB57683
Published: July 13, 2007
Unable to select Bit Index in required field for Notification setup in PAC Display
Problem was discovered in version: R8.0a
Problem is fixed in version: R8.0h
When you set up a Notification option in PAC Display using a discrete value, a bit index is required, but the field option is not available. A "Bit Index Required" message appears after clicking OK from the Discrete Tag Selection dialog. You cannot enter a bit number because the Bit field is grayed out.
After clicking Discrete (Setup By) and the Notification button, you can select the tag for the notification, but you cannot set the Bit in the Selected Fields.
[image1]
