KB57748
Published: July 16, 2007
Table data in historic log is replaced by another table's data in PAC Display
Problem was discovered in version: R8.0g
Problem is fixed in version: R8.0h
If a historic log is logging data for more than one integer or float table, the data for the most recently changed table replaces the data for the other table(s) of the same type in the historic log. This results in all tables of the same type, to appear to log the same data.
