KB57775
Published: July 16, 2007
PAC Manager error when I/O Unit Image file does not match the analog modules installed on brain
PAC Manager
Problem was discovered in version: R8.0d
Problem is fixed in version: R8.0e
In PAC Manager, if an I/O Unit Image file is sent to another brain that does not have the same analog modules installed, an error occurs. The message displayed reports there were "incompatible kernel versions."
This problem affects the following brains with R8.0a or newer firmware:
· SNAP-PAC-R1
· SNAP-PAC-R2
· SNAP-PAC-EB1
· SNAP-PAC-EB2
[image1]
