KB57824
Published: March 27, 2008
Revision: 4.0
'Move I/O Unit to Numeric Table Ex' command may write to wrong table locations
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was discovered in version: R8.0c for SNAP PAC
R7.1h for Ultimate I/O
Problem is fixed in version: R8.0f for SNAP PAC
R7.2e for Ultimate I/O
The Move I/O Unit to Numeric Table Ex PAC Control command may write data to incorrect table locations if the Points per Module parameter value is greater than 32. The valid range of values for this parameter is 1 to 32.
In addition, a -3 error should be placed in the control engine error queue, but is not.
