KB57840
Published: April 28, 2008
Revision: 4.0
PAC Control or ioControl hex string-to-number commands may give incorrect results
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was discovered in version: R8.0a for SNAP-PAC control engines
R1.0a for Ultimate I/O control engines
Problem is fixed in version: R8.1a for SNAP PAC control engines
R7.2h for Ultimate I/O control engines
The following PAC Control commands could incorrectly convert a string's numeric value:
Convert Hex String to Number
Convert IEEE Hex String to Number
Convert Mistic I/O Hex to Float
This problem is more likely to occur if the string's prior length was longer than the length of the string passed to the command.
Example
A variable, sTemp, holds a string with eighteen characters.
sTemp = "11111111111111111"
Next, sTemp is assigned the string "0x400CCCCD", which has a string length of 8 and a value of 2.2 as floating point number.
If sTemp is passed to one of the problematic commands, a result of zero or an incorrect non-zero value may be returned.
Assign a blank string to the string variable that is longer than the string to be passed to the command. In the prior example, sTemp should be assigned a blank string of at least 9 characters.
sTemp = " "
