KB57879
Published: August 8, 2007
Analog modules may incorrectly go to maximum output using B2 or E2
B2
E2
Problem was discovered in version: B2 version 9183a, R20303.00
Problem was discovered in version: E2 version R1.1b
Analog ouptut modules on a rack with a B2 or E2 brain board, may incorrectly go to their full-scale output range after one of the analog output modules is configured.
For example, a rack with a B2 has several DA4s modules installed. When one of the DA4 modules is configured, the other unconfigured analog output modules may output 5 VDC, their maximum possible output. The module that was configured remains in a normal configured state.
Opto 22 is aware of this issue.
