KB57947
Published: May 1, 2008
Reset line does not clear outputs on SNAP-B6
PCI-AC51 Pamux Adapter Card Toolkit and Device Drivers
Problem was discovered in version: R3.0a
Resolution is included beginning in version: B3.0b
Triggering the reset control line on a SNAP-B6 does not produce the expected results. Digital outputs do not turn off, and analog outputs do not clear to zero scale.
Jumper 0 on the B6 brain board controls whether the reset line is active high, or active low. Neither setting produces reset results.
