KB58160
Published: December 12, 2007
Accessing a NULL pointer may cause a Stack Overflow, Bad Quality data
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was discovered in version: R8.0c SNAP PAC control engines, R6.0a Ultimate I/O control engines
Problem is fixed in version: R8.1a SNAP PAC control engines, R7.2h Ultimate I/O control engines
If a NULL pointer variable is requested from a control engine strategy by a PAC Display project or an OPC client, a recoverable error, a Stack Overflow error, may occur.
From PAC Control, if the Debugger is open at the time the Stack Overflow error occurs, a "Stack Full" error message appears. Select the Retry button to resume normal operation. If Debugger is not open at the time the error occurs, no other indication of a problem may be apparent.
From a PAC Display project, the Event Log may log that a tag or a group of tag qualities changed to "Bad Quality." At the Opto OPC Scanner level, a "Bad Quality" message may appear for the group of data that caused the Stack Overflow error.
After the Stack Overflow error occurs, the control engine stack is cleared, and the control engine resumes normal operation.
