KB58233
Published: July 20, 2007
PAC Manager's Analog Bank feature reads the lower 4 points of high density analog modules
PAC Manager
The following are suggested workarounds for this issue:
  • Use the Generic Read/Write option (Tools→Inspect, Other→Generic Read/Write) to read high density analog module points. This area in memory begins at address F100 1000 for a module plugged into position 0 of the rack. For more information, refer to form 1465, "OptoMMP Protocol Guide", Appendix A: Opto 22 Ethernet-based Hardware Memory Map, Analog EU or Digital Counter Packed Data—Read.
  • [image1]
  • Use the Analog Point button (Tools→Inspect, Analog Point button) to read each point on the module.
Opto 22 is aware of this behavior.
