KB58310
Published: December 12, 2007
PAC Display project and OptoOPCServer clients using 64-bit integer tables may have unexpected results
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was discovered in version: R8.0a SNAP PAC control engines, R7.2d Ultimate I/O control engines
Problem is fixed in version: R8.0f SNAP PAC control engines, R7.2h Ultimate I/O control engines
Some 64-bit integer table element bit values in PAC Display projects or OptoOPCServer clients may have unexpected results. The variables appear not to change, and no error is reported. This behavior is related to controller firmware support.
Control commands affected:
Numeric Table Element Bit Clear
Numeric Table Element Bit Set
For example, if the PAC Display project contains a graphic with an operator driven dynamic attribute to set a bit in a 64-bit table element, the selected bit may not change at Runtime.
[image1]
