KB58312
Published: November 26, 2007
PAC Control action block names may be changed from debug mode
PAC Control Professional
PAC Control Basic
Problem was discovered in version: R8.0f
Problem is fixed in version: R8.1c
While in PAC Control debug mode, an action block's name may be changed by using the F2 hot key if the block is highlighted (selection handles appear around the block).
[image1]
