KB58337
Published: July 17, 2007
PAC Display AutoCorrect Tags may list unaffected tags in results file
Problem was discovered in version: R8.0i
PAC Display Configurator's AutoCorrect Tags tool (Tools→AutoCorrect Tags) may erroneously list unchanged tags in the "PAC Display AutoCorrect Tags Results File" whenever the referenced PAC Control strategy is modified.
For example, in PAC Control a connection arrow is moved, or an instruction is added using existing variables. The strategy is saved and then referenced by a PAC Display project. The AutoCorrect Tags tool is run and tags referencing bits in variables (i.e. MyController:MyIntVariableName.BIT05) are listed as changed under the "Number of tags changed:" heading. This reporting problem may lead to an unnecessary search for changes that do not exist.
