KB58368
Published: July 2, 2008
'Move Table to Table' command moves half of Integer 64 Table elements
FactoryFloor Software - OptoControl
Problem was discovered in version: R4.1a
When using the OptoControl command Move Table to Table with Integer 64 tables, only half of the elements are copied to the destination table. For example, if two tables have 50 elements and all 50 elements should be copied to the destination table, only the first 25 elements (0 to 24) are copied.
Double the Length parameter of the Move Table to Table command so that all table elements are copied to the destination table. In the above example, the Length parameter should be set to 100 so that the 50 element, Integer 64 table is completely copied to the destination table.
Opto 22 is aware of this issue.
