KB58578
Published: December 12, 2007
Revision: 4.0
'Move I/O Unit to Numeric Table' PAC Control command causes intermittent error -3
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-LCE
Problem was discovered in version: R8.0e SNAP PAC control engines, R7.2d Ultimate I/O control engines
Problem is fixed in version: R8.0f SNAP PAC control engines, R7.2h Ultimate I/O control engines
When using the Move I/O Unit to Numeric Table command in a PAC Control strategy, a possible "‑3 Buffer overrun or invalid length error." error message may be posted to the control engine error queue.
Instead of using the command:
MoveIoUnitToNumTable(I/O Unit, Starting Index, Table)
use the command:
MoveIoUnitToNumTableEx(I/O Unit, Table, Starting Index, Points per Module)
Notice the commands call the Table and Starting Index parameters in reverse order.
