KB58607
Published: December 12, 2007
Digital module states not reported accurately using Modbus/TCP protocol and Ultimate I/O
Problem was introduced in version: R7.2d
Problem is fixed in version: R7.2h
The Ultimate I/O unit states of some points on digital modules may not report accurately.
The problem is seen when a 4-point digital module is installed in positions 1, 3, 5, or 7 on a rack. When inspected, the first three points of the module show the correct state, but the fourth point does not. The fourth point's state is actually reflected in "coil location + 8". For example, coil 8, is actually seen at coil 16.
