KB58925
Published: December 27, 2007
OptoOPCServer may crash if client uses OptoOPCAuto.dll
OptoOPCServer
Problem was discovered in version: R8.0a
Problem is fixed in version: R8.1b
If an OptoOPCServer client uses the OptoOPCAuto.dll, when the client disconnects, OptoOPCServer may crash. OptoOPCAuto.dll is distributed with Opto Easy OPC VB Forms & Classes, and is used to convert automation calls (VB) into Data Access Custom Interface COM calls (C++).
