KB59015
Published: August 27, 2007
AC5 and G4AC5 cannot turn on digital output point 20
AC5
G4AC5
Problem found in cards with date codes: 05/07 through 08/07
Problem corrected in cards starting with date code: 08/07
Digital output point 20 cannot be turned on by adapter cards AC5 and G4AC5. All other output points turn on and off correctly. All digital input points, including point 20, respond as expected.
Opto 22 has resolved this issue. For cards that exhibit this problem, contact Opto 22 Product Support to arrange to have the board fixed at the factory.
