KB59170
Published: September 7, 2007
Requesting 127 Modbus TCP holding registers causes incorrect data display
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
SNAP-B3000-ENET
SNAP-ENET-S64
Problem was discovered in version:, R8.0e of SNAP PAC I/O
R7.2d of Ultimate I/O
R7.0a of Ethernet brains
Problem is fixed in version: R9.4a
Using Modbus TCP to read 127 Modbus holding registers with Ethernet I/O units causes unexpected results. Reading 126 or fewer holding registers returns correct data. Reading 128 or more registers, correctly returns a message indicating the number of registers read is too long. However, if 127 holding registers are requested, the correct information in the data fields is returned, but subsequent holding register requests results in unchanging data fields.
