KB59258
Published: October 12, 2007
Some PAC Control commands under specific conditions, may cause controller problems
PAC Control Professional
PAC Control Basic
Problem was discovered in version: R8.0f
Problem is fixed in version: R8.1a
Various PAC Control commands may cause a controller to return incorrect results and/or reset under specific conditions. Most are OptoScript commands and can cause the reset if they are used in a tight programming loop. Their equivalent flowchart command does not cause this problem.
OptoScript
Action CommandsConditions
BitClear
When Arg. 0 is an Int 32, and Arg. 1 is an Int 64 variable
BitRotate
When Arg. 0 is an Int 32 or Float, and Arg. 1 is an Int 64
BitSet
BitTest
NumberToFormattedHexString
When Arg. 1 is a Float or an Int 64
NumberToStringField
NumTableElementBitTest
When Arg. 1 is an Int 64 table
ReadNumFromIoUnitMemMap
WriteNumToIoUnitMemMap
OptoScript
Conditional CommandsConditions
IsBitOff
IsBitOffInNumTableElement
When Arg. 1 is an Int 32 table
IsBitOn
IsBitOnInNumTableElement
Flow Chart CommandConditions
Numeric Table Element Bit Test
