KB59272
Published: September 18, 2007
Converted OptoControl strategies in PAC Control may have problems converting some TPO commands
PAC Control Professional
Problem was discovered in version: R8.0f
When converting an OptoControl strategy to PAC Control, not all action block TPO commands, such as Set TPO Period or Set TPO Percent may be converted. Instead of the converted command message, an error message reporting a conversion issue is displayed.
[image1]
