KB59290
Published: June 21, 2010
Unexpected SNMP cold start traps from Ethernet Devices
SNAP-PAC-EB1
SNAP-PAC-EB2
SNAP-UP1-ADS
SNAP-UP1-M64
SNAP-UP1-D64
Problem was discovered in version: R8.0 for SNAP PAC
Problem is fixed in version: R8.2a for SNAP-PAC
Problem was discovered in version: R7.1f for UIO
Problem is fixed in version: R7.2i for UIO
The SNMP setting "Enable Cold Start Trap," at memory map address 0xFFFF F03C 0064, is being ignored. Also, two cold start traps are sent when the device is powered up. An SNMP protocol Version 1 cold start trap is sent out, and an improperly formed SNMP protocol Version 2 cold start
trap is also sent out (see KB60572 for more information on the V2-specific problem). If you are using an SNMP-compliant management system such as Computer Associates' Unicenter®, Hewlett-Packard's OpenView®, or IBM's Tivoli®, the management system may crash due to this unexpected, malformed V2 trap.
