KB59311
Published: March 18, 2008
PAC Display allows import of ioDisplay Basic project missing discrete tag bit assignment
Problem was discovered in version: R8.0k
Problem is fixed in version: R8.1h
An ioDisplay Basic project using discrete tags that do not have a bit assigned, can be imported into PAC Display without any warning about the undesignated bit. Consequetly, there may be unexpected results at Runtime.
The following graphic demonstrates how the omission occurs when assigning a dynamic attribute in ioDisplay Basic.
[image1]
