KB59334
Published: November 2, 2007
IP address with leading zeros causes error in PAC Manager's Inspect I/O Unit window
Problem was discovered in version: R8.0d
Leading zeros in PAC Manager's Inspect I/O Unit window (Tools→Inspect) IP address field, reports an error message "Error reading area: Timeout" message in the Status field, when inspecting the I/O unit.
For example, the address 010.192.54.120, or 10.192.054.120 causes the error, but 10.192.54.120 does not.
Omit any leading zeros in the IP address notation.
Opto 22 is aware of this issue.
