KB59428
Published: September 24, 2007
Installing firmware via Ethernet with PAC Manager may fail if there are files on the I/O Unit
PAC Manager
Problem was discovered in version: R8.0f
A firmware file download done over Ethernet with PAC Manager may fail if the FTP filespace area does not have room for the file to fit. The message "Failure During FTP upload" appears in the Results display area of PAC Manager's I/O Maintenance window (Tools→Maintenance).
Delete unnecessary files on the brain using Read Filenames on I/O Unit, followed by Delete File on I/O Unit from the I/O Unit Maintenance window (Tools→Maintenance). Then retry to install the firmware with the Install Firmware command.
