KB59487
Published: October 12, 2007
Append String option in PAC Display Application Manager may fail at Runtime
Problem was discovered in version: R8.0n
Problem is fixed in version: R8.1a
Application Managers configured with the Append String option, may fail at Runtime if the control engine is changed from the initial configuration. Regenerating the I/O scanner tag names does not correct the problem.
[image1]
An error message similar to the following may be displayed:
"Scan error - [Undefined Error # -2147467259 (0x8004005)] while accessing: <control engine name>:<string variable name>
