KB59513
Published: October 12, 2007
Historic data logging does not resume after reconnecting to PAC Display scanner
Problem was discovered in version: B8.0o
Problem is fixed in version: R8.1a
Historic data logs in PAC Display Professional do not resume logging if Runtime switches from the primary scanner (OptoOPCServer) to a backup server, and then reconnects to the original server. A backup server may or may not be specified. This occurs if the historic logs are configured to always log data, or to begin logging based on a Start Trigger.
