KB59627
Published: October 25, 2007
'Bit Change' command in PAC Control may cause controller problems
Problem was discovered in version: R8.0f
Problem is fixed in version: R8.1a
The Bit Change command in PAC Control may cause the SNAP-PAC-S1 and SNAP-PAC-R1 to reset if the 'Bit to change' parameter value is >31 for a 32 bit number, or a value >63 for a 64 bit number.
[image1]
The following example causes this problem:
// Setup variables
nTemp1 = -1;
nBit_to_Change = 715827882;
//Test BitChange integer (Bit 0 - 31)
BitChange(nTemp1, nBit_to_Change, nResult);
