KB59684
Published: October 15, 2007
"Uploading Recipe to File..." message never finishes PAC Display recipe upload
Problem was discovered in version: R8.0k
Problem is fixed in version: R8.1a
The "Upload Recipe to File..." message never closes after launching a recipe upload from PAC Display Runtime. Typically, the message is seen only briefly while the upload completes. The upload must be canceled with the message window's Cancel button. An error message is not posted to the Event Log.
Additionally, exiting Runtime does not close the PAC Display Runtime process. The "DisplayR.pro.exe" or "DisplayR.basic.exe" filename is seen under the Task Manager, "Processes" tab. The process is stopped manually by highlighting the filename and pressing the "End Process" button.
