KB59832
Published: November 27, 2007
Grouped graphic objects with polylines may have sizing problems in PAC Display
Problem was discovered in version: R8.0k
Problem is fixed in version: R8.1c
A grouped graphic object with a polyline of width greater than one, may have a sizing problem in PAC Display Configurator. The sizing problem may occur if the object is duplicated and the dynamic attributes are edited. For example, selecting the object so that the Graphic Dynamic Attributes window appears, and then clicking Cancel causes the graphic to resize itself.
