KB60177
Published: December 11, 2007
'Import/Copy IO Unit Image' in PAC Manager may cause error message
Problem was discovered in version: R8.1b
Problem is fixed in version: R8.1c
When working with a configuration file in PAC Manager, the Tools→Import/Copy I/O Unit Image feature may cause an error message if the Create New I/O Unit option is selected. The message appears after the Create New I/O Unit option is selected from the I/O Unit Copy/Import dialog, and after pressing OK from the Add I/O Unit dialog.
[image1]
