KB60219
Published: December 11, 2007
'View as Hex' in PAC Manager shows Int32 scratchpad area values incorrectly
Problem was discovered in version: R8.1b
Problem is fixed in version: R8.1c
If PAC Manager is used to view the Scratch Pad Integer area (Tools→Inspect, Scratch Pad→32-Bit Integers) and the View as Hex option is selected, only the first 1024 numbers (addresses F0D8 1000 through F0D8 1FFC) are displayed in hexadecimal format.
