KB60359
Published: June 26, 2008
'Convert # to Hex String' command pads extra 0's in front of Integer 64 value
Problem was introduced in version: R8.0a for SNAP PAC, R1.0a for Ultimate I/O
Problem is fixed in version: R8.2a for SNAP PAC
If the Convert Number to Hex String command is used with an Integer 64 value, then the result is a string with the converted number preceded by zeroes for the length of the string. For example, if this command is used with an Integer 64 value of 8 and a string of length 10, then the resulting string is: "0000000008".
Opto 22 has resolved this issue for SNAP PAC firmware.
