KB60378
Published: June 26, 2008
'Move Numeric Table to I/O Unit' command does not work with mistic I/O Units
Problem was discovered in version: R8.1a
Problem is fixed in version: R8.2a
The Move Numeric Table to I/O Unit command does not work as expected with serial, digital mistic I/O units (B3000, G4D16R, G4D32RS, and SNAP-BRS). The Start at Index value is correctly written to point 0 of the specified I/O unit, but all other table element values are ignored and not moved to the I/O unit points.
