KB60686
Published: December 27, 2007
Problems with PAC Control Pro when importing chart with disabled legacy I/O
PAC Control Professional
Problem was discovered in version: R8.1c
PAC Control Professional may crash if a chart referencing disabled legacy I/O units or points is imported into a strategy. The problem occurs while the chart is being imported.
To workaround this problem, enable the legacy I/O units before importing the chart. The legacy I/O units are enabled by running PAC Control Professional Configurator mode, selecting File→Stategy options, clicking the Legacy tab, and choosing the applicable legacy I/O unit group.
