KB60697
Published: June 26, 2008
Disabled I/O units are not detected by 'Error on I/O Unit?' PAC Control command
Problem was discovered in version: R8.1a
Problem is fixed in version: R8.2a
If a debug dialog's attempt to access an I/O unit or point causes an error (power was removed and then restored, for example), no error is posted to the controller error queue. As a result, the Error on I/O Unit? PAC Control command does not detect that an I/O unit is disabled.
The I/O unit can be enabled from the PAC Control debug mode I/O Unit inspection window. Select Yes for Enable Comm. and click Apply to successfully enable the I/O unit.
Another workaround is to programmatically use the Is I/O Unit Enabled? command to determine if a unit has gone offline, and then re-enable it with the Enable Communication to I/O Unit command.
