KB60752
Published: January 14, 2008
'Disable Communication to Point' PAC Control command cannot select mistic output points
PAC Control Professional
Problem was introduced in version: R7.0a
Problem is fixed in version: R8.1d
The Disable Communication to Point PAC Control command cannot select configured mistic analog output points. To duplicate this problem, start PAC Control Pro in configure mode. Add a B3000 Analog I/O unit and create an analog output point. Add the Disable Communication to Point command to an action block and select Analog Output as the Type. The mistic analog output point is not listed in the Name argument.
