KB60930
Published: June 26, 2008
Ethernet I/O units disabled if watchdogs are configured in PAC Control
Problem was discovered in version: R8.1a
Problem is fixed in version: R8.2a
Configuring a watchdog timeout from PAC Control on any Ethernet type I/O unit that is not high-density capable, causes the I/O unit to not be enabled. Watchdog configuration is done by checking the box shown below.
[image1]
