KB79038
Published: May 29, 2008
Interrupted Ethernet connection does not resume writing to Ethernet device's memory map
OptoOPCServer
Problem was discovered in version: R8.1e
An OPC application such as OptoDataLink, PAC Display, or OPCServer that is writing to an Opto 22 device's memory map and has an interruption to the Ethernet connection, does not resume writing new values even after the Ethernet connection is re-established and the OPC application continues to run. The interrupted connection can occur due to various factors such as a service interruption by the Internet Service Provider, or a disconnected cable.
