KB80013
Published: June 26, 2008
Possible momentary off pulse if digital output is already on
SNAP-PAC-EB1
SNAP-PAC-SB1
SNAP-UP1-ADS
SNAP-B3000-ENET
Problem was discovered in version: R8.1a for SNAP PAC
R7.2h for Ultimate I/O
R7.0a for Ethernet I/O
Problem is fixed in version: R8.2a for SNAP PAC
Starting a pulse function for a digital output that is already on can cause a momentary "off" pulse before the pulse function begins.
The PAC Control commands affected by this behavior are:
  • Generate N Pulses
  • Start Continuous Square Wave
  • Start On-Pulse
  • Set TPO Percent
Opto 22 has resolved this issue for SNAP PAC.
