KB80016
Published: February 28, 2008
OptoOPCServer returns truncated strings to clients
OptoOPCServer
Problem was discovered in version: R8.1d
When OptoOPCServer reads strings from a controller's scratch pad string table, the last character is truncated.
For example if a scratchpad string is set to "This is a test", OptoOPCServer returns "This is a tes" to clients such as PAC Display or OptoDataLink. The string is read correctly with PAC Manager.
