KB80029
Published: March 10, 2008
Historic logging not starting up in PAC Display
Problem was discovered in version: R8.1a
Problem is fixed in version: R8.1i
If PAC Display Runtime is running a project with a historic log, and the project is reloaded by selecting the File→Save Project and Load Runtime option, then historic logging does not run in the reloaded project. Messages in the Event Viewer do not indicate if logging has or has not started.
