KB80042
Published: March 10, 2008
SyncRead in OPCCache mode causes OptoOPCServer memory leak
OptoOPCServer
Problem was discovered in version: R8.0b
Problem is fixed in version: R8.1e
If an OPC Client uses a SyncRead function in OPC Cache mode, a memory leak in OptoOPC.exe occurs. This may eventually cause the OptoOPCServer to crash. The memory leak may be seen from the CPU Usage display under the Task Manager, Performance tab.
