KB80043
Published: March 10, 2008
OptoOPCServer's Opto Easy OPC Forms VB example does not compile
OptoOPCServer - Opto Easy OPC Forms
Problem was discovered in version: R8.1d of OptoOPCServer
Problem is fixed in version: R8.1e of OptoOPCServer
The Visual Basic source code for Opto Easy OPC Forms does not compile. An EndIf statement is missing in the TestMainFrm.frm, and the ReadItem function in CItem.cls is not handling an OPCCache source correctly.
To work around these problems, modify the following lines of code:
- In TestMainForm.frm, around line 900:
Add an EndIf statement above the line:
TheListItem.SubItems(4) = ConvertQualityToString (ThisItem.Quality)
- In CItem.cls, line 49:
If nSource = OPCDataSource.OPCCache And nSource <> OPCDataSource.OPCDevice Then
should be:
If nSource <> OPCDataSource.OPCCache And nSource <> OPCDataSource.OPCDevice Then
