KB80097
Published: March 31, 2008
PCI-AC5 causes -1 in PCI Locator when 'Blink Board' is pressed
PCI-AC5
Problem was discovered in version: PN8939A on white EEPROM label
Adapter card revision 007212C
Problem is fixed in version: PN8939B on white EEPROM label
If the PCI-AC5 adapter card is installed in a computer that is too fast to service the adapter card drivers properly, then a -1 error may be reported by the PCI Locator utility when the Blink Board button is pressed. The adapter card is identified correctly by Device Manager and PCI Locator.
Opto 22 has corrected this issue. Contact Opto 22 Product Support if the above symptoms are occuring to set up an RMA and have this problem corrected.
