KB80098
Published: December 17, 2008
Importing PAC Manager configuration file with Ethernet I/O may cause problems in PAC Control
PAC Manager
Problem was introduce in version: R8.1a
Resolution is included beginning in version: R8.2b
If a PAC Manager configuration file (.otg file) contains any Ethernet I/O type of units and is imported into PAC Control Configurator, then the I/O port is reconfigured as Serial 0. The Edit I/O Units dialog (Configure→I/O, Modify button) does not permit correcting the problem and when the dialog is closed, PAC Control crashes.
The Ethernet I/O units affected are:
SNAP-PAC-R1SNAP-PAC-R2
SNAP-PAC-EB1SNAP-PAC-EB2
SNAP-UP1-ADSSNAP-UP1-M64
SNAP-UP1-D64SNAP-B3000-ENET
SNAP-ENET-D64SNAP-ENET-S64
