KB80123
Published: June 26, 2008
Copy Date to String commands may cause unexpected control engine behavior
Problem was discovered in version: R8.1a
Problem is fixed in version: R8.2a
A SNAP PAC control engine may reset or have unexpected behavior if the Copy Date to String (DD/MM/YYYY) or the Copy Date to String (MM/DD/YYYY) command is used in a strategy, and the string variable has not been configured to be at least 10 characters long.
