KB80124
Published: July 10, 2018
Controller may reset when a variable in a PAC Control subroutine has the same name as another variable in the strategy
PAC Control Professional
PAC Control Basic
R8.1d through R10.0a
Lower versions may be affected
R10.0b
Sometimes if a variable in a PAC Control subroutine has the same name as a global variable or a variable in another subroutine, the controller may reset when the strategy is downloaded. (Normally, using the same name for global variables and for local variables in different subroutines is allowed.)
Rename local variables so they don't conflict with the names of global or other local variables.
